Blade CP Battery Charging/Discharging
Ok, the instructions with the Blade CP are not particularly complete. They mention that the batter should be discharged and that they included charger can discharge it also. How? Do I just plug the batter into the charger...and I would assume the charger should not be plugged into the wall outlet, as that should charge the battery. I presume charging the battery is more straight forward, just plug everything in and wait the stated 2 hours, or until batter is warm. Thanks for your help.
Eric
Eric
RE: Blade CP Battery Charging/Discharging
NiMh batteries do not need to be fully discharged before recharging.
Concerning the charger that came with your Blade...go spend 50 bucks for a digital peak charger. The one that comes with the Blade is junk.
2 hours to charge the battery? Forget it. A digital peak charger set at .8 mAh will charge the battery in about 45 minutes.
