am i too lean??
am i too lean??
hi i was wondering weather or not u think im running too lean. i have a venture 30 with o.s 37 and it takes off like a bullet and dosent choke or have lack of performance. it idles properly also. except when u bring her in and shut off the engine. I lick my finger and put it on the head and it sizzles for a second. there is still lots of smoke as it fills my yard with smoke. also the bottom of my tuned pipe has brown marks.. thanx in advance
ON, CANADA
RE: am i too lean??
I have the same question. I also run a venture 30 but with a OS 32. I'll burn my finger If i touch the back plate BUT if I make it richer just by one click, i get a tremendous loss of power. I can fly around and hover but any manouver that requires power is out of the question. So basically it needs to be hot to get me through the stuff i want to do (a bit of 3d, loops and rolls etc... nothing special but still power-consuming) Btw, my next investment is a OS 37... I just hope the 32 wont burn out too soon.
RE: am i too lean??
hay 1ight go the 37 i did cause i wrecked my 32 but it was well worth every penny. it flies with so much more grunt. u can realy tell the diff also get ur self a gud tuned pipe if u dont already and a set of carbon blades. im pretty happy with mine.
RE: am i too lean??
hmmm i dont know the os 37 is very poor! the port timing is very inportant in a engine this is somthing that the os 37 lacks in ...... and go on msn chigga..and i thinks your belly butten smells...
ON, CANADA
RE: am i too lean??
barracudahockey - lol ... maybe next year. Right now I am on a T6XH which as you know doesnt have that option. I think there is some way to adjust the throttle curve a bit so I might give that a try but in reality, with the way I fly now, that 32 will take a lot of beating and I dont know how long it will last. Actually I cant wait till i get something more powerful cause then i'll be able to try things i cant even think of w/ a 32. Anyways.. thanks for your input.
