JR VENTURE AND WEBRA 35
I HAVE A VENTURE HELI WITH A WEBRA 35. IT STARTS FINE BUT IT LOOSES POWER AND WILL HARDLEY HOOVER. I HAVE TRIED DIFFERENT MIXTURES AND DIFERENT FUEL FROM 15% NITRO TO 30%. HELP!!![]
My Feedback: (23)
GA
RE: JR VENTURE AND WEBRA 35
Blwj ... If the engine is to hot you will loose power. You might want to check your pitch and or pitch curve at hover. To much pitch will not let the engine rev-up, or increase the trottle curve at hover, or both. The combination should give you a rotor RPM for training at or about 1300 - 1800, and advanced 1800 - 2200. A tach under the blades will tell the story. ... Larry
Fatten up the mix....sounds like your running lean. If after hovering for a few minutes you start to loose power your overheating due to a lean mix. Might want to check your throttle/pitch curves also..
