Go Back  RCU Forums > RC Helicopters > RC Helicopter Beginners Forum
Reload this Page >
Futaba 7CHF Setup with GY401 Gyro
RC Helicopter Beginners Forum If you are a beginner or "newbie" to RC heli's feel free to post your questions right here in the rc heli beginner forum.
Old 08-17-2005, 11:26 PM
polygoo
Default Futaba 7CHF Setup with GY401 Gyro
Hey guys,
I'm new to helis... I just bought a Kyosho Cal. 30 w/ Futaba 7CHF and the GY401 Gyro. I Just finished putting everything together as per the manual, but I am having a hard time programming my Futaba 7CHF in order to work correctly with my GY401... I have read all over the place that you should first put it in regular (non-hh) mode, and then get it trimmed out (find a neutral position) then flick some "switch" 3 times in order to lock the neutral to the AVCS mode. I cant seem to find this switch that you flick 3 times, how do I set that up? I have my radio in INH mode for the Gyro, with it on "GY" mode... I dont quite understand how to switch between Heading Hold and Regular mode, how do I do this?
Also, say if I do get it setup in AVCS mode, which gain settings do I want to use? the ones on the gyro, or the ones in the radio software?
Anyway would be realyl appreciated, i've tried for 5 hours to figure this out but the manual makes no sense to me.
Basically i'm having tons of trouble getting the gyro set up, I understand everything else with the main rotor, but the gyro is just very confusing..
Thanks!
Old 08-18-2005, 07:38 AM
BarracudaHockey
BarracudaHockey's Avatar
Default RE: Futaba 7CHF Setup with GY401 Gyro
http://www.raptortechnique.com/gyrohowto.htm yes it is for raptors but its very similar, use the 9c setup that should get you in the ballpark.
Also read http://www.raptortechnique.com/gyroconfusion.htm you may want to read this first.
http://www.futaba-rc.com/team/team-tip-002.html
Let us know if you have any questions after you read all that.
Old 08-18-2005, 02:10 PM
polygoo
Wow I cant begin to thank you enough! After reading through all that stuff, I finally got it setup right and took my heli out for its first hover, It couldnt have gone any better!
thanks again!
Old 08-18-2005, 04:31 PM
BarracudaHockey
My pleasure. Glad it worked out for you! I wish I had this when I started, it would have made life many times easier.
