Noobie here, need help please
Hi
Yesterday i brought myself this RC heli http://cgi.ebay.com/ws/eBayISAPI.dll...ayphotohosting . Up till now i have only ever had RC trucks and i would usually i would post a topic here before buying into a new area of RC but there was only half an hour left when i found it. After having a look at the heli forums i discovered that this heli has quite alot of stability and control issues. Has anybody got any info or advice on how to set up this heli to eliminate the problems also any flying tips for a beginner.
all help is appreciated
Dan
Dan
CA
RE: Noobie here, need help please
if you kit came with the sims i would recommend using it. flying a heli is really difficult.
i am considered beginners too but i can hover without problem. as far on how to set up,
you have to increase the throttle trim to increase head spin. make sure your swashplate is
level.
level.
CA
nevermind, i guess your heli don't have any. just try to increase your throttle.
micro heli are hard to fly. just keep practicing and if you don't have a training
wheel i suggest you get one. its a piece of rod with ping pong balls on both end.
it will help you alot.
Fixed pitch means that the pitch (or angle) of your main blades remains the same and does not vary. Heli's like the Blade CP have main blades that change the pitch of the blades as you increase (or decrease) the throttle.
ORIGINAL: speedfreak1234
Sorry bout the double post but could someone tell me what fixed pitch meens?
[link=http://www.rcgroups.com/forums/showthread.php?t=342744] EHBG/Electric Helicopter Beginner's Guide version 15[/link]
