Mid-to-High RPM Vibration
I have a raptor 50, that i have recently repaired after a minor crash. However when i took the helicopter out to fine tune it yesterday, i observed a vibration at a little less than half throttle. At lower throttle settings there was no vibration to be observed, however as the throttle is increased past a certain point a relatively violent vibration develops, violent enuff to render the helicopter un-airworthy. I was hoping some one could help shed some light on what might be the cause of this vibration. I don't believe that the fly bar or feathering shaft are bent, as i checked these when i repaired it. However, I have not checked the main rotor shaft as yet, but i wanted to get some feed back before i do such a drastic disassembly, as i don't believe that is the cause for the vibration as it doesn't seem to be present at lower RPM's. But I could be wrong. I would appreciate the help again guys.
GA
RE: Mid-to-High RPM Vibration
check the blades, that can cause a load of problems (pitch, legnth). if it's not that I think you got a bent main shaft, of your tail could be screwed up try looking at those things, and I think you'll find your problem.
