cal 30 set up please help
NY
beginner .I can hover electric one ok.set up cal 30 in mms and when I hit throttle right side of swash does not move up and one blade does not pitch Set up to manuel specs -65 ail -65 ele +65 pitch and the servos reversed as in futaba set up shown.Should I set up in mms or is ems alot harder to fly.
thanks
thanks
CT
RE: cal 30 set up please help
MMS stands for Mechanical Mixing System, and EMS stands for Electronic Mixing System. With your radio (7C) you have support for EMS which I would say is better than MMS due to simplicity. If I were you I would start over and set it up for EMS, thats what I did and i'm a beginner too. I took one look at MMS and personally, I think i'd trust the electronics over mechanics.
NY
In the beginning I called futaba and they told me to set up in hr3 but I guess the person I talked to is wrong.hr3 is for ems and h1 is for mms
thanks
thanks
