RC Helicopter Beginners Forum If you are a beginner or "newbie" to RC heli's feel free to post your questions right here in the rc heli beginner forum.
GAIN?
Old 01-20-2006 | 02:20 PM
Default GAIN?
Can someone explain what GAIN is for?
Thanks.
Old 01-20-2006 | 02:27 PM
VinceHerman's Avatar
Default RE: GAIN?
Gain controls how aggressively the gyro attempts to correct tail deflections.
Low gain, and the gyro makes small corrections to the tail signal.
High gain, and the gyro makes large corrections to the tail signal.
Higher gain is typically better, allowing the gyro to do more of the tail steadying task. But if the gain is too high, it 'over-corrects'. This produces a tail-wagging condition, whare the tail oscilates back and forth rapidly.
For answers to this and many more questions about helis, take a read through the [link=http://www.rcgroups.com/forums/showthread.php?t=439631]EHBG[/link]
Vince
Old 01-20-2006 | 02:32 PM
Default RE: GAIN?
gmmwicked .... Can someone explain what GAIN is for?
Relax and be still ... I'm trying to read your mind!
OK I'm assuming you're refering to the gain setting of a gyro on an RC heli.
The gain of the gyro is how sensitive to movement it is and how efficiently its output is. If the gain is set too low then the gyros output to the T/R servo will not be enough to stay up with what the heli is doing. Really low and it's like not having a gyro. If the gain is set to high the gyro will try to make corrections faster than the servo and heli can respond to it (heli gets jittery).
What's it for? To control the heli in a way that pleases you.
It is generally adjusted either on the gyro itself or via your TX via an available channel on the RX (channel 5 for the Futaba).
Gain is also a clothes washing detergent. In this case, Gain is used to get your clothes cleaner.
Good Luck,
d.tipton
Old 01-20-2006 | 02:44 PM
BarracudaHockey's Avatar
Default RE: GAIN?
Please don't do that while I'm drinking, I think I just spit pepsi through my nose!
Old 01-20-2006 | 08:45 PM
Default RE: GAIN?
Yes, I was talking about the clothes detergent.
What is this GYRO hubub you speak of????
J/K
