Blade Cp Problem
MI
Hey all. Ive had my Blade Cp for about a month now and have now been able to keep the CP up in the air for almost an entire battery. I thought it was time to do some upgrading so I purchased a few Lipo batteries, a Lipo charger, an E-sky 9 tooth motor, upgraded landing gear, and also replaced my tail motor cause it went bad. With all my new stuff the CP flies for much much longer. The only problem I have is: When I first plug my lipo battery in and begin to fly it wants to turn way to the right. So I make adjustments on my remote which only makes it worse. So I do my best to keep it straight with the controls and then after a few minutes it starts to turn nose left on me. So at this point I unplug my battery to reset the CP and center my controls.....then it flies perfect, straight as an arrow. After like another 10 minutes it seems to want to do the same thing again so I have to reset it again. Does anyone know why I have to keep reseting it. The tracking of the blades is a little off....but that shouldnt cause that to happen right? Hopefully someone can help me out. Its just irritating when it is flying perfect and then just starts flying crappy on me. Thanks.
Oh and another thing....is direct drive the way to go with the CP. Pros and Cons?
-Mike
-Mike
VA
Thats natural for any tail-motor driven heli...it will never really find center...sometimes its better with lipos, sometimes it worse..if you havent already, upgreade to the direct drive motor on the tail, will help alot..
MI
So I need to get the one that is titled Direct Drive / Large prop & fin tail system upgrade? What else do I need to purchase if I order it? Can I use the same stock tail motor? Will the stock tail blade work? Sorry for so many questions...haha Thanks
-Mike
-Mike
