Change pitch? Wobbling
IL
Hey all I am wondering what I need to do to get my bird to quite wobbling. It seems to want to tilt forward and just seems off balance. I started to take the head assenbly off, but got caught at getting the center hub off, so just decided to put things back. Are there minor adjustments I can make instead of taking the whole thing apart? Thank you
IL
RE: Change pitch? Wobbling
Thanks for your help. I appreciate it. Could it be any of these? 1.) Flybar uneven? or 2.) pitch on one of the paddles of the flybar? I am not sure if they are both supposed to have the same pitch, but one looks like it is tilted more than the other. Much appreciated!
Thats your problem. The paddles need to be aligned perfectly with each other.
Its easier to do than describe.
Also the fly bar w/o the paddles on needs to have the same amount showing on each side AND after you put the paddles on they need to be the same distance from the center of the head.
