hows my new header tank look>
RE: hows my new header tank look>
header looks nice. a few suggestions or comments where is the fuel filter?? the ground wire for the glow plug extension could be shortened and attached to the bolt just above it (gets rid of dangling wire. foam wrap the rx .The yellow wire i assume is for the gyro its a power wire next to the antenna??
Just trying to help
ps if your into a header tank maybe time to get rid of the training gear.
Just trying to help
AL
Here's mine:
Couple of things I noted about your set up ...
1) Secure the gyro wire away from the spinning stuff ... main gear, belt gear.
2) I don't like the 3 port setup on header tanks. [Unless you got two clunks in the tank] You will have to put your heli on its nose to de-tank your system. Filling is OK ... Flying is OK ... De-tanking is a hassle. This is why its common to find a t-fitting between the header and the carb. It can easily be de-tanked via the fill line because the fill line has a clunk in the header tank. And it's also common to have a t-fitting that also has a filter in it.
Good Luck,
d.tipton
Good Luck,
d.tipton
I have to agree. I use a T also and it took 4 different ones until I found one that works.
You got a really nice clean setup there Tippy.
AL
skyad ... Tippy no rear servo tray yet ...
Yes ... I do have a tail boom mounted t/r servo. So the next question would be "what's with the original t/r servo linkage then?"
I use the front half of the original t/r servo linkage as my battery switch control. I took a MPI switch and installed a ball link into the switch lever. I built a little plywood filler panel to mount into the original t/r servo bay and installed the switch into the plywood. I then used the front linkage half and just mounted it to the switch. I left the linkage coupler on so I would have something to grab hold of.
So my on/off switch is the coupler. Kind of easier to reach without having to pull the canopy or stick your finger through that little hole in the canopy. Here's some photos in case you're confused.
Forward end of linkage:
Aft end of linkage:
Good Luck,
d.tipton
AL
Doahh ... I'm sorry but what is a header tank?
Plus it adds a few more ounces (of fuel) to your fuel capacity.
Here's a repeat of mine (with text added):
Good Luck,
d.tipton
Hi Tippy,
Very neat job there.
What is the bright green instrument up front their?
Presume it is an on-board monitor but what make/model
CHAKA
CHAKA
GA
Its called a temp guage/fail safe what this mean is that one your temp goes to lets say 280 your fail safe will engage and cut down the throttle till your temp goes down.http://www2.towerhobbies.com/cgi-bin...&I=LXJTW3&P=ML
GA
We here in the Uk do not have the luxury of Hobbico or Tower.
I searched all the Uk sites trying to ID it but could not find anything like it. Found current/volt monitors.
CHAKA
CHAKA
