hummingbird v3 questions
AK
just got my v3 and i was wondering if the plastic wrap on the flybar paddles is to stay on(i have seen it in all the pictures and they ARE still on. Also, how loose/tight do the main rotors have to be? thanks, mike
MN
RE: hummingbird v3 questions
My Elite didn't have wrapping. Can't figure why you would need it. If it's loose, take it off. If it's tight, probably doesn't matter as long as they balance. Main rotor blades should be tight enough to have some resistance to movement but not loose enough to have vertical wobble.
