What is trimming and why/how do you do it
OH
I have seen in many posts indicating that most new RTF birds are not in fact RTF and actually need to be trimmed prior to acheiving RTF status. Can anyone advise as to the how and why of trimming (or point me to a similarly responsive article as I am sure someone has typed about it before) and is there any other useful advice for newby in terms of initial bird setup? All responses are truly appreciated.
RE: What is trimming and why/how do you do it
Hi,
Depending on what model you get, there is a wide range in the quality of the assembly, and the quality of the parts.
Making adjustments to the linkages to get smooth, slop-free action is very important.
Blade tracking, balance, gyro gain and centering settings. Motor breakin. Things like that.
As for tips, take a read through the [link=http://www.rcgroups.com/forums/showthread.php?t=439631]EHBG/Electric Helicopter Beginner's Guide[/link]
I also recommend that beginners NOT get RTF. Assembling a kit gives knowledge about the heli, and how to work on it. You will need these skills after your first crash.
But, most of the bottom dollar birds are RTF.
Vince
PS - sending you a PM
Vince
AL
jhunter68: I have seen in many posts indicating that most new RTF birds are not in fact RTF and actually need to be trimmed prior to acheiving RTF status. Can anyone advise as to the how and why of trimming (or point me to a similarly responsive article as I am sure someone has typed about it before) and is there any other useful advice for newby in terms of initial bird setup? All responses are truly appreciated.
Why? It's such a nice feeling to allow your heli to hover on it's own with little stick input. This only happens if the servo to control linkage is "trimmed". For example, if your rudder is not "trimmed", you will spen your entire flight leaning on the rudder stick. While it may be flyable, it's a nuisance and cuts into the "fun" factor. Same thing with cyclic. If your trim setting is close enough to adjust out with the trim on the heli, that's good except when lots of TX trim is used, use are displacing some of the function of the control movement (at least in the direction of trim).
So ... it really makes for a more enjoyable flying experience if you DON'T have to bias a control with a constant stick movement. Ideally, a heli should be trimmed so that it can at least momentarily hover with no hands on the sticks. This won't happen when the heli is "untrimmed".
Good Luck,
d.tipton
OR
Now at least I have confirmation of what I thought a Helicopter should do.... Hover without your hands on the sticks. THANKS.
Last Friday I bought a CP Blade (and I am new to RC) and the tail turns to the left and when giving more throttle the nose goes to the left and a bit down. I was wondering why?
I guess I will have to play around with the trim.
cpnewby
cpnewby
Banned
Same boat here, can you elaborate upon that last statement, I'm doing a major crash course, still learning the terminology about this.
AL
tippy: ... momentarily hover with no hands on the sticks. ...
barracudahockey : ... Most helicopters don't hover for hands off very long ...
cpnewby: ... Hover without your hands on the sticks ...
Chris_s :... you may also have to adjust the proportional pot on the 4in1
Espresso-Outfitters: ... can you elaborate upon that last statement
Both are methods of trimming the t/r thrust to match the torque forces in order to maintain YAW control.
Good Luck,
d.tipton
Banned
Well made my first flight, I kept it short since there was wind I was fighting, that and the landing gear broke when I landed it too hard, I gave myself plenty of space out in a field with spongy grass/soil to cushion the learning process, will leave the battery mount stock since I'd rather it fly off upon impact rather then drag the chopper with it. So far have made some progress trimming it, at least got it off of the ground correctly, will take the next run just as easy, I can't wait to reach a point where I can fly it in my backyard.
ON, CANADA
ORIGINAL: barracudahockey
Most helicopters don't hover for hands off very long any more than a spinning basketball will stay on your finger tip without minor corrections.
