Mini Dragonfly problems
I need some help, I bought a feda mini dragonfly and it was assembled and i turned on my reciver with full batteries and then centered the trims and centered both thumb sticks, Then i plugged my full charged battery into the helicopter(took of the blades to try it) and in the manual it says let it sit for 5-7 seconds to calibrate then the led light would turn green and all circuits will be active. Well I plugged it in and the red Led light came on and i let it sit and it would never turn green it doesnt respond to anything, when i move it rapidly the led light turns green then red again. Well maybe about three times i would be trying everythign and it wouldnt move and then suddenly the light would turn green and it would fly up and crash with no control like i was applying no throttle and it was just turning on its own as if there was circuit lose that once and a while would connect and fly or maybe something else with the same frequenzy is making it do that. I don't know but can someone help me maybe anyone who has a dragonfly tell me exactly what they do to start it up or tell me what you think is wrong with it, help a newbie out. Thank you.
CA
RE: Mini Dragonfly problems
I have a similar one, and it flys fine. The above advise is good. You should have a manual that tells you all of this. Another thing; think spell check.
