nexus 30
WI
nexus 30
i just got a nexus 30 and was wondering if any main blades will fit, and were is the best place to get parts???? i dont have a manual with it so i am really reaching, i had one years ago and just trying to get back in cheap....any info will help thanks
RE: nexus 30
If I remember right the Nexus blades are 520mm (or 530mm), most 30 size helis have 550mm blades. Your probably going to have to use the right blades, if you use the 550mm blades I doubt you will clear the tail blades. Take a measurement from your blade grip bolt to the tip of your tail blade, that will tell you if you can use 550mm blades (I don't think you can, but I could be wrong).
RE: nexus 30
Send me your email address and I'll email you the manual or send you a link to an ftp where you can download them.
Those were 535 mm blades, anything longer will hit the tail blades. Helimax might make some, check Tower Hobbies, 550 is too long for the Nexus.
As for parts, http://www.caliber30.com can get what isn't discontinued, other than that, you'll have to try EBay
