Go Back  RCU Forums > RC Helicopters > RC Helicopter Beginners Forum
 Engine getting too hot. >
RC Helicopter Beginners Forum If you are a beginner or "newbie" to RC heli's feel free to post your questions right here in the rc heli beginner forum.
Old 04-18-2006 | 06:24 AM
Default Engine getting too hot.
I have a Hawk Sport with an OS 32 in it. I just got it as a first heli, and I am concerned about how hot the engine is getting. It puts off alot of smoke, but when I try to richen it up, the tail wobbles. I am afraid to lean it to bring up the rotor speed because I am afraid of cooking the engine. How hot are these things supposed to get?
Old 04-18-2006 | 10:10 AM
BarracudaHockey's Avatar
Default RE: Engine getting too hot.
If you are using heli fuel they smoke alot.
The way to temp test the engine is to put your finger on the backplate, if its cold you can go leaner, if its warm but you can hold your finger there atleast 3 seconds its about right, if its too hot to hold your finger there its too lean.
Fly around then land quickly and check it right away, a bit of hovering and or a few laps around the field is good enough if you aren't into aerobatics yet.
Old 04-18-2006 | 10:58 AM
Motions's Avatar
The smoke test is a really bad way to judge mixture on helis. You can run them extremely lean and still smoke quite a bit. The best method is the finger on the backplate test like cuda recommends and with experience, the sound of the engine can tell a lot.
Old 04-18-2006 | 01:59 PM
Pain thresholds also make the finger method not all that accurate... but its better than smoke.
Old 04-18-2006 | 03:13 PM
My theory on that is if you have enough sensation in your hands to manipulate the sticks to fly a heli you won't have any problem with the finger to backplate method.
