RC Helicopter Beginners Forum If you are a beginner or "newbie" to RC heli's feel free to post your questions right here in the rc heli beginner forum.
blade tracking
Old 08-22-2006 | 11:01 AM
Default blade tracking
HI their I am very new to rc helicopters and i was just wondering what is blade tracking and how to fix it if their is a problem?
Old 08-22-2006 | 12:20 PM
BarracudaHockey's Avatar
Default RE: blade tracking
Blade tracking is when both blades are flying in the same plane, from the side you will see one straight line. OOut of track bladese appear as 2 blades side on, this causes vibration.
Normally if you set the blades to the same pitch with a pitch gauge and they are good blades they will be in track, if they are cheap blades or out of balance the first thing you do is carefully balance them, then you can adjust the links to the blades to get them to match up.
There's some pictures and such on http://www.raptortechnique.com look around at his pull down links, one of them describes it.
Old 08-22-2006 | 05:28 PM
Go to www.raptortechnique.com. Look under Adjustments-Alignments -> [link=http://www.raptortechnique.com/bladetracking.htm]Blade Tracking[/link]
Here is an image from that page:
Good Luck,
d.tipton
