RC Helicopter Beginners Forum If you are a beginner or "newbie" to RC heli's feel free to post your questions right here in the rc heli beginner forum.
hover stick position
Old 09-26-2006 | 01:44 PM
Default hover stick position
Hi guys do you hover at half stick or are you setup for 3/4 stick
Old 09-26-2006 | 02:03 PM
BarracudaHockey's Avatar
Default RE: hover stick position
Most 3d guys use 3/4 stick so that when you switch to idle up the heli doesn't jump.
Old 09-26-2006 | 02:37 PM
Kevinator9's Avatar
I buddy box and am doing the basic like hovering, nose in and landing etc. To get the club heli into a steady hover I need 1/2 stick to hover.
Old 09-26-2006 | 07:28 PM
Bigunit,
As Barracudahockey mentioned, use the 3/4 stick method. You may have to adjust your pitch a tad, 1/2 turn or so either way. But it does make a difference in stability and control. You need the head speed.
Dave / Choppersrule
Old 09-27-2006 | 01:45 AM
thanks guys will stay ant 3/4 and see how it goes
cheers
Old 09-29-2006 | 06:41 PM
3/4 Stick when Ideal up on or off when hovering. What about the throttle trim, off or on? If my trim is off the Blade CPP will not hover at all on full stick.
Old 10-01-2006 | 03:50 AM
ross001's Avatar
I started out at half stick and was told to change to 3/4 for idle up. Its fine either way but if youre using idle up its better to be at 3/4 stick.
Ross
