Thread lock agent
I am about to build my heli.
The instruction recommends me to use threadlock for some bolts. It says to use "Hobby Tight".
I saw a threadlocker BLUE (medium strength) by Prmatex from Walmart. I wonder if it is sufficient or too much thread locking agent for r/c heli.
Be careful, if you use a bonding agent that bonds really well you can almost forget getting that screw out. The threadlock is really only meant to stop the screw from backing out during vibration.
I use Lok-Tite brand of thread lock. You can get it at most dealers of industrial fasteners (screws, bolts, etc). The BLUE color #262, is what I use on my helis. It holds under the most adverse vibrations, but is easily removed when you want. The GREEN color is mostly for cylindrical parts like securing bearings to shafts, which you won't need for your heli. The RED is for a permanent installation. The only way to remove the part is with heat! Don't use it unless you plan to NEVER remover the part!
Rod
Rod
TX
Hi zzzz,
Yes, sorry... My post was meant to be a 'green light' about using the blue permatex... It works well for a medium strength threadlocker. I've used it for a long time with no issues at all. It holds well, but can be 'broken loose' without heat if needed...
