Auto Hub question?
OH
Auto Hub question?
I am building a Raptor 60 v2 and I have found the one way bearing to be a bit sticky when everything is assembled.
Turning the main shaft, without the head assembly installed, it takes a fair amount of pressure to rotate the shaft while holding the top, grey, gear still.(yes it will only turn in one direction)
How freely should this turn?
What can be done to loosen up the one way bearing?
