PLEASE HELP!
hello ive bought a honeybee cp2 and on my first flight the battery cable got court in the disk thing than turns the rotars it then burnt the 4 in 1 reciever thing out so i purchased another and connected it up but the blades are not rotating very fast and not producing any llift at all and the the tail motor seems to be going at normal. anyway most of u will probably reply that u have the tail motor lead and blade motor leads mixed up but this isnt the case as ive switched them round and its just the same can anybody help please??
You might of killed the battery in the process of frying your 4 in 1. If the battery lead got caught in the main gear and it may have loaded up the motorm which drew an enormous amount of Amps and toasted the battery. Maybe evem the main motor.
