RC Helicopter Beginners Forum If you are a beginner or "newbie" to RC heli's feel free to post your questions right here in the rc heli beginner forum.
Learning to adjust
Old 02-12-2007 | 07:38 PM
Default Learning to adjust
i just bought a new tx, and while try to set it up, i come to the part about sub-trims. i have read manual over and over, but i just can't understand this subject. can anyone explain in simple language what the bnefits are for using them. an example would help a lot. thanks
Old 02-13-2007 | 09:28 AM
HeliTB's Avatar
Default RE: Learning to adjust
Sub trims are different from the trims on the face of the radio. When trying to set your servo arms up at 90 degrees as most instructions say can be challenging due the servo arms teeth not mating properly on the servo at 90 degrees. This is when you use the subtrim not the standard trim. The subtrims allows you to get that servo arm at 90 degrees without going crazy.
Caution: If you need more than 20% subtrim in either direction it's better to take the servo arm off and move it one click on the servo and then reset the subtrim to 0 and try again to get the servo arm to 90% with the subtrim.
Old 02-13-2007 | 12:04 PM
HeliTB,
that was a perfect explanation! thanks..........
Old 02-13-2007 | 01:37 PM
a very good site with explanations on radio set up is....[link=http://www.raptortechnique.com]very good site[/link].....hope that helps
Old 02-13-2007 | 03:28 PM
BarracudaHockey's Avatar
Always try to achieve mechanical neutral first, use sub trims only as a last resort or too much and the servo will actually move farther one way than the other.
