RC Helicopter Beginners Forum If you are a beginner or "newbie" to RC heli's feel free to post your questions right here in the rc heli beginner forum.
Beginner's Question
Old 02-25-2007 | 02:32 AM
Default Beginner's Question
I have been practicing with my new Heli-Max AXE EZ for a few days now, basically just hovering indoors. Today I took it outside in a big field where I figured I couldn't get into much trouble. I took it up about 50-80 feet & a few seconds later it went almost straight down & crashed. I'm still puzzled what I could of done. Could someone suggest some possibilities so I don't do it again? I don't believe I cut the power on the collective stick. The Heli was badly damaged but all the electronics seem ok. I just ordered nearly everything else so I can get it back in the air. Any advice would be greatly appreciated. BTW there was little or no wind.
Mike T.
Old 02-25-2007 | 09:33 AM
VinceHerman's Avatar
Default RE: Beginner's Question
Hi Mike,
Did the heli quit?
Or was it a case of loss of orientation?
I know that the first time I flew up, and it was only 30 or 40 feet, I found that I could no longer tell what the heli was doing. It resulted in a death dive that broke the frame of my heli. I simply was not used to viewing the bottom of the rotor, so I lost all of my visual cues about what the heli was doing. I don't fly anywhere close to overhead now.
Vince
Old 02-25-2007 | 09:54 AM
Vince, I think it may be just what you said. The Heli was overhead & I must of lost my orientation. From now on I will keep it in front of me.
Mike
Old 02-27-2007 | 07:11 AM
mike when i firist started, back when there wasnt sims, i was told to start by hovering just out of ground effect till really sick of it then with the tale away, then sideways, then i was told to fly away and do figure 8's towards you ( out and back)...this will help you with the problem of oriantaion....keep going though and dont get frustated it will pay off in the long run...good luck
