NO LIFT!!!!!!!!!!
NO LIFT!!!!!!!!!!
I bought a used shuttle (.30) huey, went over it and gassed it up today, throttle up all the way but no lift at all. What adjustments do i need to make to transmitter or heli, Instincts tells me some adjustments need changing within transmitter parameters, i have a futaba 9chp, somebody help!!!! please.
AL
RE: NO LIFT!!!!!!!!!!
ORIGINAL: mustangshooter
Lift comes from several basic things ... blade size, RPM, and angle of attack (blade pitch) and whether or not that lift produces flight is determined by heli weight. Atmospheric conditions can have an affect on produceable lift also
So give us your pitch angles at bottom, mid, and high stick ... this can be measure with a pitch gage (without the engine running of course). Without enough pitch your heli won't fly and you'll over rev your engine. Too much pitch and your engine will bog down.
What is your main rotor RPM ... is the engine bogging down or is it got plenty of rev's???
Tippy those things i don't know presently, tomorrow i will check those out and post them here, the rpm seems to be ok it revs up quite strongly but no pitch from the blades.
TN
AL
mustangshooter:: ... no pitch from the blades.
Remember what I said: ... Lift comes from several basic things ... blade size, RPM, and angle of attack (blade pitch).
Get the pitch thing sorted and then the real fun will start.
BTW ... I use the 9CHP also.
Tippy today i found the the culprit that was preventing my shuttle from achieving lift, turns out guide pin on radius block was on top of slide block thus preventing pitch arm from moving when throttle is applied, i loosened the hex screw, set pin back in place and now the pitch arm is moving high-low thus main blades moving in opposite direction as they should, I was trying to upload some photos but hasn't yet download cd for camera (don't know where it is at the moment), will try later again, thanks for all the inputs, they made me thoroughly went over heli to be able to find this bug.
