Go Back  RCU Forums > RC Helicopters > RC Helicopter Beginners Forum
Engine starts in wrong direction >
RC Helicopter Beginners Forum If you are a beginner or "newbie" to RC heli's feel free to post your questions right here in the rc heli beginner forum.
Old 03-22-2003 | 12:50 AM
Default Engine starts in wrong direction
I have a os 32h engine in a Century Hawk sport, all brand new.
I have experience with glow engines in aircraft and now I have these problems:
1. while turning over engine with starter(ccw) it seems to be backfiring, and hard to turn over.
2. when it starts 8 out of 10 it starts backwards.
3. when running fuel spits out of carb. (direction?)
Old 03-22-2003 | 01:19 AM
Your engine is too rich or your fuel is siphoning from the tank. Try pinching the fuel line then see if you can get it started, let it clear out then release the line. I have a fuel shut off on my X-Cell to prevent siphoning.
Old 03-22-2003 | 03:04 AM
FLYBOY's Avatar
Make sure you have the starter plugged in right and if this is your first heli, get some help before you hurt someone. We had this conversation with a guy a couple weeks ago and he ended up flying into his truck. Better that than into someone standing there.
Old 03-22-2003 | 03:33 AM
Default plugged in the right way
Ah yes plugged into the right way......... When looking at the crank end, the engine turns CCW-- correct , and blade leading edge leading. CCW engine rotation correct? Then I'll tell you what I use to start engine!
Old 03-22-2003 | 09:49 AM
Its a common problem when the low end is a bit too rich. Try scerwing in the low end needle a small amount (les than 1/8th turn) at a time until the problem stops.
Old 03-22-2003 | 04:57 PM
Default replies
Thanks for the help (constructive)
