flight
can i use my same pitch setting for hover also for flight it is set at 0 to 10 on high end pitch i have been hovering for about 2 months i do not want to do 3d know just want to fly it around for know have not set up idle 1 an 2 my book said these are for 3d flying i have a 8u super futaba an a jr ventura 30 with a 401 combo with servo i think i am ready to fly thanks
NY,
you're better off with a couple of degrees of negative pitch at the bottom if you're going to fly around. it will let you lower the helicopter in a level attitude instead of pitching the nose down. with 0 to 10 it's going to climb out okay but float a lot on the way down.
