Go Back  RCU Forums > RC Helicopters > RC Helicopter Beginners Forum
 Engine tuning help please? >
RC Helicopter Beginners Forum If you are a beginner or "newbie" to RC heli's feel free to post your questions right here in the rc heli beginner forum.
Old 12-27-2007 | 02:28 PM
Ecklund1's Avatar
Default Engine tuning help please?
Where do I find some good "how-to"s on engine tuning? I'm about to fuel up my OS 50SX-H for the first time and want to make sure it's set up right. I know (at least) rich is good on running in a new mill. But, I read varying and conflicting information regarding factors affecting performance like needle settings, head temperatures, weather conditions, moon phase, DOW Jones, etc.
I know that the number of turns on the needle is only a guide and, ultimately, the answer seems to be "properly tuned". How do "expert tuners" learn? Everyone is a noob at least once. []
Thanks in advance,
Jeff
Old 12-27-2007 | 03:27 PM
Big feet's Avatar
Default RE: Engine tuning help please?
Hi Jeff,
I know where you are right now, after 17 years of fixed wing I still had no idea how to tune a heli engine. The methods we use for planes just aren't possible.
There are others on this fourm much better placed than me to answer this question, and have done in the past. Do a search at the bottom of the page in this fourm and you should find some good info.
I put an OS 50 Hyper into my Titan last year, I strongly suggest putting a prop driver and propeller on the engine and running it in on the bench before you fit it to your heli. This will do two things for you.
Firstly. Better access to play with the needles and learn your engine settings, without putting your heli at risk. The prop wash also keeps it cooler. You can lean out the engine on the final tank at full throttle and listen to it to determine the best neddle setting. Then back off from this between a quarter and a half turn and the heli will be somewhere near right. When you do fly, at the end of the flight land and spool down the blades, immediately touch the back plate of the engine. If you can keep your finger on it for 4-5 seconds things are good, if it is too warm you are too lean, take the neddle out another half turn and try again.
Secondly. Once the engine is run in (about 8 tanks of fuel) you can setup your final throttle and pitch curves from the start. If you fit a new engine you will need to run it rich at first, and therefore less power, so run more throttle or less pitch to compensate.
Hope this helps.
Old 12-27-2007 | 04:02 PM
Ecklund1's Avatar
Thanks for the reply. I thought about bench running the engine before I installed it, but nothing anywhere by OS or Heli-Max indicated that it was a necessary break-in method. I really don't want to yard it out of the Heli at this point. I have been going through the set-up of EVERYTHING as meticulesly as possible to alleviate first flight woes. Between the factory instructions and helpful RCU modelers, it's just about dialed to a "T".
I'll be scale flying for the forseeable future, so I'm more concerned with engine longevity and reliability versus squeezing every erg of horsepower and rpm out of the engine.
I've many different points made about how rich to run it as well. Some gauge the richness by smoke volume and I've read where that isn't the best gauge as different fuels produce different amount of smoke. And how would that work with supposedly "smokeless" fuels anyway??
Jeff
Old 12-27-2007 | 04:04 PM
BarracudaHockey's Avatar
http://www.raptortechnique.com has two great articles on beginner and advanced engine tuning
Old 12-27-2007 | 04:17 PM
Ecklund1's Avatar
Cool. Thanks Andy.
