RC Helicopter Beginners Forum If you are a beginner or "newbie" to RC heli's feel free to post your questions right here in the rc heli beginner forum.
flybar
Old 01-15-2008 | 02:39 PM
Default flybar
Can I use as a flybar for esky belt cp, a bicycle spoke cutted at the correct size?
Thank you
Old 01-15-2008 | 03:12 PM
Default RE: flybar
It's ok with me. I look at the carbon flybar as kind of a fuse though, it breaks easily and keeps you from really tearing stuff up.
Old 01-15-2008 | 04:41 PM
Default RE: flybar
You know they are like 2 bucks for two flybars, right? Also, the paddles screw onto the flybar on the end. Might want to check that out as well...
Old 01-15-2008 | 05:49 PM
Default RE: flybar
where do u get carbon flybars at? It seems these will save your carbon paddles as well.
Old 01-15-2008 | 07:25 PM
Default RE: flybar
I would think that you could use just about any carbon rod that is the right diameter cut to length and just once you get your paddles level and the grub screws locked, put a drop of ca on the bar where it meets the paddle, wicking action will pull the ca into the joint and lock the paddle in place, it should thread itself as youtwist the paddle onto the rod so the ca might not be necessary, but I don't want a paddle flying off in the air and causing you to crash or maybe hurting someone, I'd rather glue it.
Old 01-16-2008 | 04:50 PM
Default RE: flybar
do the flybars have threads at the end or are they solely held in by the set screws?
Do you think carbon rod is going to have the stiffness of the original flybar?
Old 01-16-2008 | 08:32 PM
Default RE: flybar
Somebody knows the belt cp flybar size?(long)
Old 01-18-2008 | 12:36 AM
KezzerOne's Avatar
Default RE: flybar
I have a HBFP, which I believe has the same flybar demensions. I measured mine to be 17cm... Keep in mind that is the length of JUST the carbon fiber rod without the paddles.
Old 01-18-2008 | 12:55 AM
Default RE: flybar
the flybar for the king is threaded at the end, that's why I would use a drop of ca to go along with the set screw just to be safe. I would think that carbon would bejust as stiff if not stiffer than stock, and much less weight, so faster response, less stable of course, but it would break instead of bend in a crash, which could be good or bad
Old 01-18-2008 | 12:56 AM
Default RE: flybar
I seriously do wonder how much of a weight loss is possible on the king, i mean if you go all carbon and go with the lightest available parts, even change out to ceramic bearings. I would love to go ceramic but I don't own the bank.
(edit)
I just now realized that i am the only one talking about the king..... I didnt pay my attention bill and they shut me off.
