RC Helicopter Beginners Forum If you are a beginner or "newbie" to RC heli's feel free to post your questions right here in the rc heli beginner forum.
AH-64 Apache heli
Old 02-25-2008 | 06:44 PM
Default AH-64 Apache heli
Hi,
I bought an Ah-64 Apache heli. How does this thing work. It barely has enough power to get off of the ground. And then the tail goes in circles and it can't be controlled. It is a coaxial so how does the tail stay in one place? Ok this is a generic brand. The Tx is able to become a 4ch. It will function like a 4ch but it is only a 2ch. I guess in case you would want to make it into a 4ch. Anyway when I use the knob for the tail to go L or R nothing happens.Could something be wrong in the Tx? What should happen when I try to swing the tail? Is there a difference in the way the coaxial moves? waht should I do or look for?
THanks
Old 02-25-2008 | 09:31 PM
The_Shark's Avatar
Default RE: AH-64 Apache heli
if its 2ch take it back, they are junk and nobody has luck with them, but the colco lamas and apaches are awsome (4ch)
the co axials models use this technolegy to make it super stable, and gets rid of the tail because it turns and stays put by slowing or raising speed in the motors.
for instance to stay put both blades spin the same speed, to turn one motor slows down so the other pushes the craft the opposet direction.
as for the lack in power i dont know, if there is a throttle trim, turn it up.
good luck
