lama v4 going backward
HI All ,I have the esky v4 for my grandson??? Out of the box new looked over seemd alright ,When powering up it will fly backwards ,plenty of lift no problem there .Ican lightly capture the tail apply power it lifts off the more power fed in ,it wants to move backward.First flight straight up 40ft +moveing rearward all the time.should the 4in 1 unit mix the speed with the elevator servo(i can see no movement).can anyone help with this problem or am I doing something wrong. Regards Dave
AB, CANADA
the swashplate is probably not set up correctly. pop off the link on the swashplate from the elevator servo and turn it to make it longer. do one full (must be full turns) at a time until it flies level with the elevator trim in the center.
HI Druss. Thanks for advice nice to know there's someone out there, will have a go at that.I did look at the attitude of the blades but even a small adjustment will make a large difference. Thanks again Dave
