Basic home material Upgrade for CO-Comanche
Banned
FL
Basically after I had my Co-Comanche for about a couple days one of my wheels broke off, so naturally I went online to helidirect they were out of stock of coarse. So then I started thinking about how I could balance the heli with out touching the ground? So heres the steps
1. get some ping pong balls from a old trainer set
2. cut the other wheel at the same spot that the other wheel broke
3. aply pressure to the ping pong balls, where sticks go through
4. tape up the wheels to make sure they dont fall off in flight ( I use metal tape works great)
5. (this step is up to you) ad a extra support bar on the bottom of the ping pong balls with tape
If you need any help or want to contribute to this thread go go ahead and post or PM me.
-KMK
-KMK
