RC Helicopter Beginners Forum If you are a beginner or "newbie" to RC heli's feel free to post your questions right here in the rc heli beginner forum.
Servo stutter
Old 04-03-2008 | 03:29 PM
Default Servo stutter
OK I noticed that in flight, especially at higher head speeds, my HBK2 would kinda twitch every now and then, I set the heli down and slowly moved the cyclic and noticed that my front servo would kinda of stutter and twitch at near center stick if I just barely moved the stick the servo would shake, I replaced the servo and it still does it. I am using the stock transmitter and servos. Any ideas as to what could be causing it? I have some of my own thoughts but I would like to have them confirmed by more experienced pilots before i go and do anything serious.
Old 04-03-2008 | 03:48 PM
Default RE: Servo stutter
Mine did that and I put a ferrite ring on the wire from the ESC and it stopped it. Now I have a ferrite ring on everything.
Old 04-03-2008 | 03:53 PM
Get this! I took the transmitter apart and wiped down all the electronics with wd-40 because I read in one of these threads somewhere, (A belt cp thread) that it cleaned up the signal from the TX, and.....IT WORKED! no more stutter on the servo. I allready have a ferrite ring cactus, so I figured that couldn't be it. but I can't imagine if i didn't have one.
Old 04-03-2008 | 04:12 PM
Could you be a little more specific as to what you wiped down, maybe I need to do that.
Old 04-03-2008 | 04:35 PM
I have one of the WD-40 pens, I just used it and went over the backs of all the PCB's and i wiped down every electrical connection inside the transmitter. and I put a drop inside all four pots. I'll post pictures as soon as i get my camera back from the inlaws.
Old 04-03-2008 | 04:53 PM
I have some spray electrical contact cleaner, I'll Just take the back off and hose it down and then blow it out with my compressor.
Old 04-03-2008 | 05:08 PM
Sounds good
