what are servos for?
ME
Well, A servo is a gear box that is used to move a control surface on a model aircraft, or to control throttle, and steering in a model car. basically a servo consists of a motor a gear box and an electronic controller that is used to control the position of the horn or the "throw of the servo.
AL
ORIGINAL: jakgamer
what do servos do?
what do servos do?
What do servos do? They move something mechanically based on an electrical command given to them.
ORIGINAL: jakgamer
what do servos do?
what do servos do?
A signal is sent from the transmitter to the Receiver. The receiver decodes the signal into a "command" to the servo. The servo moves whatever is attached to it based on the command given by the receiver. A receiver is capable of controlling several servos. All this is powered by a local power source, usually a battery.
I hope this was simple enough.
Rafael
