Coaxial heli trouble
just bought a new beginners coaxial heli. straight out of the box flying, just that it doesnt fly straight from the box. i can clearly see that my bottom main rotor is slower than my top one. 1) causing it to spin massively out of control. and 2) because it doesnt turn fast enough it doesnt provide the lift it should so cant even get off the ground!!!
Help!?!?
Help!?!?
RE: Coaxial heli trouble
Gday there,
What is it you are flyin?If its rtf out the box then you shouldnt need to touch the 4in1 allthough it does happen.
Make sure the rudder trim is central,and no loose connections to bottom motor.
Thanks for the responses. ye i tried trimming and everything but i dnt think its to do with tht. i took the landing gear off and had a look at it while it was going i think the cogs may be slipping on the B blades. do you think that would be expensive to get fixed?
and its a cheap 3channel fly eagle one. nothing fancy. had an esky lama V4 beforehand but completely broke it. off to uni so thought id go for acheaper option as im happy with anything tat flies!
Cant really help you with those 3 channel ones but i asume they work more or less the same as the v4.Sounds like your right
about the cog slipping tho.Shouldnt be expensive but may be time consuming.
Sorry i cant be more help
