esky comanche
whats up guys. here's the thing, i've had my comanche for awhile and after a crash a couple of weeks ago, at full throttle it doesn't want to go higher than a couple of feet. any ideas?
Gday mate..
Is it spinning while flying..if one motor isnt working correctly it will spin around like crazy being a coax.
If your at full throttle and it wont go up then the blades arnt spinning fast enough.
Pretty much the only reason it wont go up is lack off upward lift.
Are there any other side effects from your prang or is lack of power the only problem?
I found on mine that when it didnt want to fly but sat on the ground and spun at full speed, the problem was on the main shat it has 4 small black scews that came loose and wouldt engage the main to lift, turn the shaft till screws find the holes and tighten them up, but dont over tighten, plastic hates that.
hope this helps.
Nigel
hope this helps.
Nigel
