Any Cellpro 4s Charger users here?
I just got my w charger and dont know what mode I should be charging in. There is 1.0c lipo, 2.0c lipo, and 3.0c lipo modes. I'm using 1800mah and 2200mah, 3cell packs. Can anyone tell me which I should be charging at? Thank you
Gord
Gord
RE: Any Cellpro 4s Charger users here?
ORIGINAL: droggy
Gord
Gord
Jim
On pg. 3 of your manual it tells you what mode to select. That you SHOULD do before plugging battery pack in. After that it will automatically do the rest for you. however, it is best for battery to be charged at a 1.0C mode but take your choice. Hopefully you have read the warning about requiring a power supply of at least 5A. on pg 4.
NS, CANADA
ORIGINAL: droggy
Gord
Gord
Lm
What does the "C" stand for? I've read the manual, just don't know the difference between 1, 2, and 3 c. Thanks for all the advice guys
NS, CANADA
If you were charging at 3C, you would be charging at 3 times the capacity of your pack. In the case of your 1800mah pack, 1C would be 1X 1800ma (1.8a) If you charged at 3C, you would be charging at 3X 1.8a=5.4 amps. Hope this makes sense.
Lm
Lm
GA
I wouldn't just go charging every lipo at 2c or 3c just because the charger has an option to do so. You may not notice any problems with your packs right off and you may not burn anything up but you could shorten their lives. I can't say i've tested it but most manufacturers don't reccomend charging over 1c for a reason (in this litigous society I'd assume that reason as not being sued when you burn your house down or worse).
I charge my AT packs at 2c but they are capable of it. If they were some cheap packs I didn't care about I might risk it if I watched them charge but on pricy lipos I won't bother as I'd prefer longevity of the pack.
MB, CANADA
well, i charge all my batteries at 2C with the Cellpro 4S charger, but all my packs are 3s 2100 mah packs, and 3 2200 mah 4s packs. some have up to 75 cycles on them like this..... the Cellpro charger slowly brings the charge rate up, then charges at peak rate, then slowly brings it back down..... its been safe for me.
twice i tried the 3C setting, just to see how fast it would go, i dont thing it ever exceeded 4A.
