HBFP is turning right
I ran the first battery through my HBFP last night and had a few questions. I kept the heli on the ground the whole time just getting use to the throttle and tail movement (following RADD's school). Anyhow, at low head speed the heli wanted to yaw to the right instead of the left. So to keep the tail straight I had to apply some right rudder. All of the trim tabs were centered. Now as it got light on the skids it would start skidding to the left as expected. I obviously have no idea what it will do once it's airborne, but since it is already yawing to the right should I adjust the 4/1. Maybe the rpms are too high on the tail?
Also, is it normal for the heli to have some slight vibration? It seemed like every other spin up there would be some vibration, but it would go away.
Already addicted and haven't even got off the ground. Glad I have some patience.
Thanks for the help
Thanks for the help
AL
RE: HBFP is turning right
engineer04:: ... the heli wanted to yaw to the right instead of the left. .... I had to apply some right rudder.
