Heli receiver for airplane
WI
I recently bought a DX6i and upgraded my Honey bee FP. I now have a transmitter and reciever from the 4 in 1 on the heli and i was wondering if i could then use that in a foamie plane i was building. The plane will have its own ESC.....i was just wondering will it work so i dont have to buy a AR6100e.
MI
im not sure but im thinking as long you have the right servos in the right ports it should work
what you have 3 servos on a foamy left right up down and pitch,. right?
then again the radio its self may not operate in the same mannor
wow maybe you should call tech support at a good online vendor that sells both heli`s and plane`s
ORIGINAL: Elite160
Enjoy!!!
Jim
AB, CANADA
I don't think it will work easily. The 4in1 unit is a combined receiver, gyro, mixer and esc. They all work together. In order to separate out the esc from the other parts you need to open up the unit and disconnect the two boards. Do a search for threads where people have modded these to use a brushless system.
FL
Elite...I think Druss is right about the 4-in-1. You may also have a power issue...how to power both ESC & the 4-in-1.
Cool concept though....may be better off buying a 72 Mhz receiver and put the crystal from the 4-in-1 in that instead....that actually sounds like the path of least resistance if all you're trying to do is use the heli TX in the foamie.
I still stand by my statement. Usually mixing is in the transmitter and not the receiver. Here is a test. Plug the servos in and if you can work the servos individually left and right. If so, no sweat GI. Foamies can be 2 channels, 3 channels, 4 channel and up. Try it and let us know. Correct me if I am wrong but the FP is a fixed pitch? If so no mixing would be involved. So I see no problem.
Jim
Jim
FL
dooleyje, in most cases you are correct about mixing (i.e., TX handles that). In this case the 4-in-1 has mixing in it irrespective of whether the FP needed it or not (it's 1 of the 4 parts of the 4 in 1), but with only 1 motor on that heli it didn't effect anything. That may or may not be an issue though (if the foamie has 2 motors...???). The real issue probably lies in the fact that foamie may have brushless power...if so, the brushed powered 4-in-1 won't be able to power the foamie's ESC/motor. It could work...but UGHH....what a PITA job for a crappy gyro.
I would say that we can agree to disagree and still be wonderful freinds. In part you are also correct if the heli he was referring was a ccpm verson with pitch control. The FP is actually only a 4 channel receiver with no pitch control so there will be no ccpm mixing. The right and left servo are seperate in control and function. The motor is not mixed with the pitch. It is not a coaxle heli so the motors are not mixed with the gyro, The rudder or tail does have a gyro involved but that no problem either. Plug a servo in where the tail motor was and enjoy the gyro for torque rolls. I do agree that a brushless motor would not work if the heli had no such setup and you will have to use the internal ESC. I would just use a motor of the same type and current draw and get a foamie that matches the power provided. Of course it is possible. I have seen it done. Sometimes we can think out of the box and acheive great things.
Jim
Jim
FL
![Big Grin](https://www.rcuniverse.com/forum/images/smilies/biggrin.gif)
FL
Jim - Jensen Beach is about 100 miles north of Miami on the east coast. I actually lived in miami too.....6 years while going to school at FIU (BS & MS). I have since hopscotched my way up the east coast over the last 10 years from Sweetwater & Kendall to N miami, to Delray Bch, to Palm City and now I've settle my bones in Jensen Beach....which used to be a pineapple plantation back when Flagler's original rails were still in operation. I love this area.
Loved living in Miami when I was there too, but am glad I'm in a more peaceful setting ya know![Big Grin](https://www.rcuniverse.com/forum/images/smilies/biggrin.gif)
Way way back I once went to a Jimmy Buffet concert in Charlotte and was amazed at all the good looking chicks everywhere....I almost didn't leave Charlotte that weekend.
![Smile](https://www.rcuniverse.com/forum/images/smilies/smile.gif)
ORIGINAL: FLYGUY09
Jim
WI
OK well what it worked. i Wasnt trying to ues it for gyro or anything. I was just using the reciever for it....with a seperate esc and brushless motor. Everything works fine....just thought i would update....now to assemble the darn thing
