CX2 Battery
NV
Ok, So I charged my battery, made a flite. Didn't crash! HA! Now.... I plug my battery to the charger. Do I have to watch it like a "hatchling" or can I go to sleep? Will it be damaged if I wake up tomorrow?
SJQ
SJQ
KY
make sure to read the section on lipo's in the manual. its usually the first warning you get in a lot of manuals. you should NEVER, EVER leave a lipo unattended while charging. you should always unplug it when it is finished charging. they are very safe to use as long as you follow the rules for lipos.............................td
KY
also i forgot to mention. it is equally important to make sure that you do not discharge the battery too low, it will cause permanent damage to the battery. when the heli requires more throttle than usual to keep it in the air, its time to land and charge the battery...............td
trex 450,,,,,trex 500,,,,,,,lepton ex,,,,,,,stinger 90,,,,,,,,,,,,,,,,,,,,,,,,,
