Go Back  RCU Forums > RC Helicopters > RC Helicopter Beginners Forum
 having problem with my axe cpv3 >
RC Helicopter Beginners Forum If you are a beginner or "newbie" to RC heli's feel free to post your questions right here in the rc heli beginner forum.
Old 03-13-2009 | 08:36 PM
Default having problem with my axe cpv3
I was flying and all of a sudden my tail rotor stop spinning I changed the motor and still no spin I checked the polarity and no spin I checked the motor on the power supply and it spins. What would be next?
Old 03-14-2009 | 07:35 AM
Default RE: having problem with my axe cpv3
If the main rotor IS working then it could be a problem with the 3 in 1 board (tail ESC), the connection to the motor, a Rx connection problem.
If you're sure the tail motor and capacitor is good (it works with a different power source, etc.) then work back to the 3 in 1 and verify all connections.
Old 03-16-2009 | 07:15 AM
Bugzilla's Avatar
Swap the motor connectors, i.e. the tail plug in the main motor slot and vice versa, and power up SLOWLY. If the tail motor spins and the main doesn't, you need a 3n1.
