Go Back  RCU Forums > RC Helicopters > RC Helicopter Beginners Forum
 Which locktite to use.... >
RC Helicopter Beginners Forum If you are a beginner or "newbie" to RC heli's feel free to post your questions right here in the rc heli beginner forum.
Old 03-25-2009 | 07:08 AM
FLYGUY09's Avatar
Default Which locktite to use....
....on the my Belt CP V2's steel feathering shaft? The 5.5 mm bolts have a white plastic inside the bolts. So which threadlock should I use (steel & plastic combo)???
Any help is appreciated!
Old 03-25-2009 | 09:19 AM
Default RE: Which locktite to use....
ORIGINAL: FLYGUY09
Threadlock is reported to attack most plastics and should only be used for metal to metal contact. I use a drop of thick/med CA.
Jim
Old 03-25-2009 | 10:50 AM
FLYGUY09's Avatar
dooleyje - thanks for the help!
I've got foam safe CA I use for one of my jets. Do you think that'll be OK?
Old 03-25-2009 | 05:54 PM
That will be fine.
Jim
Old 03-25-2009 | 08:46 PM
FLYGUY09's Avatar
I was thinking it would work....thanks again Dooeyje!
