Trim adjustments
CA
Trim adjustments
I have a Belt-CP V2, everytime I start to lift off the Heli veers left. I have the trim tab all the way to the right. I tried adjusting the linkages going up to the flybar. Is this the correct linkages to be adjusting ? Also should the paddles on the ends of the flybar be level with each other ? Than you in advance for your help.
RE: Trim adjustments
It's normal for the heli to veer to the left on take off. You will need to have the heli
in a hover to determine if the trim is right.
Yes the flybar paddles should be level with each other.
