Another cnc question
I would like to upgrade my esky belt cp V2(ek1h-e602) to cnc head and tail assembly. Do they make a pre assembled combo set. Just learning and I am confused on what parts will work. Most upgrades are for, I think, belt cp. Are they the same? Just crashed and thought it would be a good time to upgrade but not sure how. Sorry if this question has been asked. Any ideas would be greatly appreciated.
JEEPHARLEY - Cnc is nice but if you are learning your better off getting plastic parts as they are cheaper. ALso if you tear into it and replace a single part as opposed to swapping out the head you will learn a lot more about the bird and what each part does. But if you are looking for a complete head, check out JAGHOBBIES.COM I was on his site two days ago and he has all the carbon fiber and cnc for the belt cp V2, preassembled ready to drop in, or individual assemblies. You can also check USHOBBYSUPPLY.com. I just started dealing with them and they are fantastic. From Belt cp to Belt CP V2 most of the parts are not interchangeable. I found that out when i wrecked and all the plastic parts were on backorder from Esky. Check out those two sites and you will find what you need. Both are fantastic to deal with and I have personally dealt with both.
Mike
Mike
PA
ORIGINAL: gagt2nv
Mike
Mike
Here is the parts list for V2. The numbers are the same for V1. I am using even the blue vertical tail fin on V1, tail boom ect, main gear, tail blades, skids.........
Cheers
I found when i went to replace parts in the head that the v1 to v2 had small differences. You can get them to work but it just takes a little thinking and know how. If there are parts that are direct fit then i def. did not find those. JEEP said he wanted something to bolt right in so that he didnt have to mess with the head. I just steered him to the two stores. If you look on their websites, most of the parts for the head are different part numbers if im not mistaken. Just trying to keep it simple as possible for him cuz I know this stuff can get really confusing.
Yea siree
Gagt answered your question specifically and correctly. I was referring to in general.
He is correct about the head. The V2 tail has the upgraded tail slider.
Cheers
Cheers
MI
I bought the CNC head and tail on Ebay from china. The whole set is $31 shipped. I am very happy with it. Many people will tell you that the Ebay set is crap however, it is basically the same as the 150 dollar set.
