DX7
NJ
Was wondering any of you with a DX7 how long are you getting out of your battery before your battery warning starts beeping at you? and what is the max volts it charges to?
I never wait for the warning. Mine gets charged before every flying session. If you insert a Lipo option as Drobin has then you will get about ten times the flying time. The lipo option is very popular. Always remove the battry before charging though for safety and never charge it unattended.
Jim
Jim
NJ
Thanks Drobin and Dooleyje I went and ordered the Lipo from helidirect. I was getting like an hour out of my stock battery before it would start beeping at me. Just inthe set up alone on my heli i had to charge the battery in the middle of set up. Figured stock battery get more then an hour but the lipo should solve this issue cause i use my TX often cause i use it with Phoenix Flight Sim. Once again thank you
