Can I Use 2 Tx to control One Heli?
I would like to split flight controls between two operators each with his own transmitter and control responsibility - one for flight control/navigation and one for camera control. Is it possible to have two 2.4GHz transmitters controlling one heli? Is it possible to bind two 2.4GHztransmitters to one receiver, each using mutually exclusive channels? Or can I use two independent pairs of 2.4GHz Tx and Rx?
MI
RE: Can I Use 2 Tx to control One Heli?
You won't be able to bind 2 Txs to the same Rx on the same profile. You could use a buddy box and have each person use different controls.
Either way if you wanted a Tx to control a camera (I'm assuming you mean for moving it around) you probably won't have enough channels with one Rx anyway.
ORIGINAL: wyobob
I would like to split flight controls between two operators each with his own transmitter and control responsibility - one for flight control/navigation and one for camera control. Is it possible to have two 2.4GHz transmitters controlling one heli? Is it possible to bind two 2.4GHz transmitters to one receiver, each using mutually exclusive channels?
Look closely at the following picture. It was taken from an RC helicopter. The guy in the middle of the field is flying the helicopter. The guy at the edge of the porch is looking at a monitor to line up the shot with a second remote. Picture taken from here: [link]http://rc.runryder.com/helicopter/t431441p1/[/link] Pilot is Ken Stitt and I am on the camera controls.
Rafael
MI
Hah that's really cool, first I've seen something like this. I've noticed a lot of vibration in a lot of heli-mounted cam videos I've seen, does that make it harder to line up the shots?
ORIGINAL: TakeshiSkunk
For more pictures like this one, you can surf this site:
[link]http://rc.runryder.com/helicopter/f25p1/?top=1268428359[/link]
Specifically this thread:
[link]http://rc.runryder.com/helicopter/t32252p1/?top=1268428428[/link]
It was a breeze to line up the shot that day. The only problem we had was trying to communicate between the pilot and I since we were so far away. That heli is smooth as silk.
Rafael
Thanks.I will probably be getting a 9 channel radio to handle everything. So I guess I would have to get two of them and connect with a slave cable. Or maybe two recievers with 6 channels each would be a cheaper solution if they didn't interfere with each other and add too much weight to the heli.
