Beginner question and more
As some of you, I am completely new to r/c and I have decided to start with heli's. After reading some reviews, I picked up the Megatech House Fly 2. Very happy with it and after only a few days I am getting around my basement pretty good. Being completely new to this I have a ton to learn but a few questions:
As expected I have had a few run ins with furniture, floor, ceilings, etc...I now have a pretty decent shimmey/vibration that I can't seem to get rid of. Still flys great...but... Checked the weighted fly rod and as did the best job possible making sure it was completely straight and true, but can't completely get rid of the shimmy...thoughts?? The Li Po battery that came with it - is the charger that came with it safe to continue to use or is one of the balanced chargers a better way to go? That is it for now - thanks! aammcc |
RE: Beginner question and more
I would say that if the shake started after bumping into stuff you might have bent one of the main shafts. If you already checked the flybar and it did'nt shake before the only thing that is left is the main shaft.
Excellent - Thanks for the reply. I will check into that.
You bet, let me know if thats the fix or not and if you need anything else just ask.
Dumb question - What is meant when they say a heli is 3D?
hi aammcc when a helicopter goes 3D i believe it means it does aerobatics you know flips, rolls etc
Yeh thats about the stupidist term isnt it? Every heli flys in 3D. Freestyle aerobatics is much better.
I just invented "4-d" aerobatics.
I'll do them tomorrow. ;) |
That is what I thought on the 3D question - Thanks! Also - I still have a way to go to getting comfortable with my Housefly, but what is the next heli I should be looking to get into. Thanks!
The Li Po battery that came with it - is the charger that came with it safe to continue to use or is one of the balanced chargers a better way to go run the battery down between charges. I generally fly my heli till i begin to notice significant power loss (50% power loss from the throttle). I am new to the heli thing too but li-po batteries are all the same. Good luck and have fun! |
| All times are GMT -8. The time now is 10:27 AM. |
