RCU Forums
-   RC Helicopter Beginners Forum (https://www.rcuniverse.com/forum/rc-helicopter-beginners-forum-165/)
-   -   threadlock (https://www.rcuniverse.com/forum/rc-helicopter-beginners-forum-165/542480-threadlock.html)
rickjc 02-08-2003 05:27 PM
threadlock
Hi, I did it now. Got tired and stupid, lost a drop of blue threadlock and it fell on my throttle barrel. Tried to clean it up but some seeped inside. There is a bit of binding. Is there something to dissolve it or do I have to take the carb apart?
Culverson 02-08-2003 06:04 PM
threadlock
Acetone should remove it, I would be very careful making sure every bit is out of any moving mechs in the carb. You might want to very carefully disassemble it and try using a soft tooth-brush with the acetone to get it cleaned properly.
I use gloves when using any kind of solvents & read precautions on handling..
rickjc 02-08-2003 10:43 PM
threadlock buster
Thanks Culverson for the info about the Acetone, it worked good.
I don't think I could tackle taking apart the carb at this time. Way to much going on. Are you supposed to lubricate the throttle barrel ever?
Rick
PaulSwany 02-11-2003 07:04 PM
threadlock
You're glow fuel will lubricate the carb.... But after disassembly, cleaning and reassembly, I use a little marvel mystery oil... Or you can use ATF...
