Rotor Blade Rotation
I have a eksy belt cp - Main rotor rotates clockwise - tail viewed from the right rotates counterclockwise. Is this correct? Manual indicates both should rotate clockwise. Thanks
RE: Rotor Blade Rotation
The tail rotors should swing up into the rotor downwash. So if you are looking at your heli's right side, it would rotate CCW.
Thank You
