Top End Pitch?
Top End Pitch?
My setup is a Raptor 30 with a Webra 35CH engine fitted with the TT "Deluxe" muffler.
I run the engine on 10% Coolpower and it has had about a gallon or so and exhibits excellent compression.
My question is what would the maximum pitch such a setup could take without overloading the engine. At the moment I am getting just under 8 degrees - should I be looking for more?
Thanks in advance
Thanks in advance
Top End Pitch?
Gary, the top pitch your heli will pull is determined by the engine HP and the blades you use. The Webra with a stock muffler and 10% fuel probably won't pull any more than what you are getting...to get +/- 10 degrees might require higher nitro (which Webras don't seem to like!) or maybe a tuned pipe and 15% fuel. Chris
