RC Helicopter General Discussions Discuss RC Helis here. Nitro, gas, turbine and any make, model or brand not having its own specific forum below!
ESC programming card
Old 11-28-2011 | 04:54 PM
Default ESC programming card
A while ago I purchased a Turnigy ESC prog. card. (the white one) Was able to program the ESC on my RCX 450 with an RCX ESC/BEC. Everything went great.
Today I tried it again and NOTHING, the card lights up and that's it. No blinking anywhere. I am aware that this card isfor"specific" ESC's howeverhow did it
worked two weeks ago andnot now? Polarity is OK, it's being donethrough the ESC slot on the card and then power is applied.
Any help will be appreciated</p>
Old 12-17-2011 | 09:20 AM
Default RE: ESC programming card
First of all, you should try the card on another ESC to find out if it's working.<div>I had one of those which burned after two uses...</div>
Old 12-17-2011 | 02:13 PM
Thanks for your input, guess their QC is way below par. I did tried it with another RCX ESC
with the same result. I also got about two sessions on it before it went.
They are designed for the hobbywing "software" which is the same used in the RCX brandESC.
By any chance, do you know of a reliable card that works onHobbywing s/w ?
I can do it via the TX; but out in the field
it gets messy with the background noise.
Cordially
Felix
</p>
Old 12-21-2011 | 01:33 PM
Sorry, can't help you there... but if you find anything i'll be happy to know!
Old 12-22-2011 | 06:11 AM
ATVAlliance's Avatar
The programming card that xheli (hobbypartz, nitroplanes, nitrorcx) sells is the same one with different branding on it.
Just so you know.
Old 02-08-2012 | 04:17 AM
very useful,thanks</p>
